July 25, 2019 at 2:37 pm
nilo
SubscriberHi.
I am trying to verify the offshore wind turbine response in ANSYS AQWA and FAST. The problem is that when I add a regular wave in AQWA it gives me the responses of motion in a different phase which is due to the difference in wave generated in the codes.It seems the remedy to solve this issue is to run one code and then get the waves as input to the other code.
Does anyone know which code allows me to have surface elevation as input in ANSYS AQWA?
Thanks in advance,
Nilo
July 25, 2019 at 3:12 pm
DrAmine
Ansys EmployeeMoving to structural for better audience -
July 29, 2019 at 4:22 pm
Sandeep Medikonda
Ansys EmployeeWhat version are you using? If you are using let's say 192, can you run the following command in a command prompt and paste the output here:
"%AWP_ROOT192%..Shared FilesLicensingWinx64ansysli_util" -checkout AQWAWAVE
Of course, if you are running a different version please change %AWP_ROOT192% accordingly
2120
1347
1118
461
