How to get wave elevation graph in CFD-Post?
    • Mushtaq
      I am currently running a simulation of open channel in a numerical wave tank for modelling of offshore waves as shown in Figure given below.
      Forum Moderator
      Create an iso surface on the free surface (VOF = 0.5 is usually good) then plot that with the up coordinate against the across coordinate. n
    • Mushtaq
      Create an iso surface on the free surface (VOF = 0.5 is usually good) then plot that with the "up" coordinate against the "across" coordinate.https://forum.ansys.com/discussion/comment/97450#Comment_97450
      I am simulating a 2D tank so I am unable to generate ISO-surface. Only Iso clip can be created for the VOF=0.5. Can you please send me some links where I can find the solution of my problem. Also please provide more details about 'up' and 'across' coordinate.n
      Forum Moderator
      Up and across will be x & y coordinates. nAs you're in 2d that means you're using Fluent, so we can extract all the data directly during the run. Create vertical lines at each monitor position and use iso-clip to create a point at the free surface. Report the position of that. If you click on Help in Fluent you'll be taken to the documentation and, more usefully for you, a load of tutorials & how-to videos. Do the tutorials & watch the videos. n
    • Chakra Chand
      Hello Rob, I am also having similar issue. I am able to plot the x & y but I want to plot for x & y for whole running time. Actually I want to see the elevation wave elevations with time passing on. Can you provide me some references where I can look for?
      Thank You
Viewing 4 reply threads
  • The topic ‘How to get wave elevation graph in CFD-Post?’ is closed to new replies.
