March 1, 2022 at 12:23 pm
murali666
SubscriberI am trying to simulate a 3D flow filed around a cylinder using Large Eddy Simulation. My flow domain is given below, where the cylinder and bottom surface are specified as no slip boundary conditions.
March 2, 2022 at 1:38 pmKishan Konannavar
Ansys EmployeeHello
One approach to try could be to split the domain in such a way that it allows you to chose the region/surface to add inflation layers. For example, if the domain is split into 3 regions, upstream of BOI, BOI region and downstream of BOI then you may control the meshing in these volumes.
Hope it helps
Regards
Kishan
March 2, 2022 at 1:48 pmmurali666
SubscriberHow can I split the domain in ansys and how to combine them together?
March 3, 2022 at 1:15 pmNikhil Narale
Ansys EmployeeHello,
At the CAD level, try to separate the surfaces where you want to assign different inflation layers setting (Hint: Use imprint or intersect tool). In the Ansys meshing, you can insert multiple inflation settings in the outline tree and assign it individually to different surfaces. Let me know if this works.
Nikhil
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2706
2146
1357
1144
462
