How to have bonded contacts and initials state at the same time
    • ehsan120
      Hi,nnI have several parts that they are connected with bonded contacts (I cannot use the sharedtoplogy since it will make so many difficulties for making a good quality mesh). All these parts has initial states (strain or stress). The problem is that when I introduce these initial states, bonded contacts are not recognized by the solver and parts start showing the penetrations. I removed the initial stats and thing are working properly. Is there any specific setting for the contact in this problem that I can change and solve this issue?!nIs there any better way than bonded contact to tie parts in ansys?.Thanksn
    • Ashish Khemka
      nnCan you share the initial contact status using Contact Tool?.Regards,nAshish Khemkan
    • ehsan120
      nnThanks for the response. I am a newbie in Ansys so those setting are mostly default settings. Attached you can find a simple example of what I am trying to do. I really appreciate you help in advance.Thanksnn
