August 26, 2019 at 12:31 pm
vidyadhar.kpm
SubscriberHello,
I am doing a VOF simulation with liquid and vapor. The two phases are separated by interface, which is spread over few cells.
Now, I want to identify liquid cells (F_C0, THREAD_T0) adjacent to the interface, so that I want to apply some source terms in these liquid cells.
To do so, I need to find the "face thread" of the interface cells.
I request anyone to let me know how to do this?
Thanks & Regards,
Vidyadhar
August 27, 2019 at 5:06 am
DrAmine
Ansys EmployeeYou need to identify interfacial cells through cell loop and the you might identify related faces and face threads. I will rather use a source term weighed by area density which is only non zero at interface. -
August 27, 2019 at 5:18 am
vidyadhar.kpm
SubscriberHello Amine,
If I apply source terms at the interface, then:
1) what if the interface is spread over three to four cell layers
2) what if the interface is contained within a cell layer? How to achieve this to happen? Does gradient adaptation helps?
Thanks & Regards,
Vidyadhar
August 27, 2019 at 5:25 am
DrAmine
Ansys EmployeeThat can happen especially if you are diffuse algorithms and underresolved. Here you need to distribute the source term.
That us why better to weight the source term by interfacial area and you Do not need to identify and interfacial cells or threads. -
August 27, 2019 at 5:35 am
vidyadhar.kpm
Could you please elaborate upon "weight the source term by interfacial area"
In a VOF simulation, is the interfacial area density estimated by Gradient of Volume fraction?
August 27, 2019 at 12:14 pm
DrAmine
Ansys EmployeeYes.
Regarding weighting: find a way to distribute the source terms across interfacial cells. As I wrote: I will go with the interfacial area density approach.
2524
2066
1279
1096
457
