Ansys Products
Ansys Products
How to identify number of licenses consumed by LS-Dyna (For Network Based Licensing)?
    • Ansh
      Detailed step-by-step methodology would be helpful.n
    • ANSYS_MMadore
      Are you running LSTC LS-Dyna, or ANSYS LS-Dyna in Workbench?.Thanks,nMattn
    • tslavik
      If you are using the LSTC License Manager, and if you are saving a license log, then you can use the lstc_logreport utility to extract usage information. I'm not sure it will give you everything you want, but give it try. Execute the program with no arguments to print a SYNTAX statement:nnSYNTAX:./lstc_logreport input_logfilen             [-begin MMDD[[YY]YY]] [-end MMDD[[YY]YY]]n             [-sort [user|host|program|status]] [-rev]n             [-csv]n             [-out out_file]nnThe input_logfile should be the name of file specified as the log file for the LSTC License Manager. The Window version automatically uses lstclm.log as its log file. Linux/UNIX servers require you to specify the name on the command line using a -l option (i.e., lstc_server -l logfile_name). The output has a simple format. Use -csv to save in a format that can be imported into Excel.n
