How to imitate/copy certain portion from user definitive primitive?
    • umozumder
    • Navya C
      Hi @umozumder
      You can draw 3d shapes that intersect with the unwanted portion and then use the subtract boolean operation to remove those portions.
      OR, you can draw a cube with the teeth dimension and a cylinder with the inner diameter of the stator and then use subtract operation to get that shape.
      Regards Navya
