Discovery Import
Discovery Import
How to implement Ramped Loads in AIM?
    • m.zanoletti
      I'm trying to implement a ramped (or Custom) load in AIM, but I find only constant factors to multiply each loadstep. Thanks Michele
    • Naresh Patre
      Hello  M.Zanoletti
      I am mentioning the response from Glyn that you got yesterday:
      In the context of Structural Analysis, there are a couple of options:
      1) Use multiple load steps and vary the multiplication factor per step as per Richard's suggestion.
      2) Use manually defined sub-stepping (in Solution Progression) to see equally spaced portions of your applied conditions (if it's just ramping up to a given magnitude) - that said, you can see this without sub-steps by going by percentage in the result.
      3) Use the "time-dependent structural" beta feature to enable tabular entry.  You can exclude inertial effects by turning Time integration (in Solution Progression) to Off.
