November 15, 2018 at 7:13 am
VSK1989
SubscriberDear Team Ansys
Greetings . I have problem importing 2D geometry from Solid works to Ansys Aim .
Thanks in advance .
V Shravan koundinya -
November 15, 2018 at 7:15 am
Keyur Kanade
Ansys EmployeeYou can export parasolid or step or iges format from Solidworks.
If the geometry is not complicated, you can always create in SpaceClaim or Design Modeler and then you can use that geometry in AIM.
November 15, 2018 at 9:32 am
VSK1989
SubscriberHi,
thanks for the response. I could not mesh the 2D geometry . Please let me know if I have to change any Settings in ANSYS AIM .
Thanks and regards
November 15, 2018 at 12:40 pm
Aniket
Ansys EmployeePlease update the thread with inline images of the model along with detailed error message that you are getting, so that it will be easy for all the members to help you better.
November 15, 2018 at 2:17 pm
Keyur Kanade
Ansys EmployeeSo you can import the geometry. Please mark this thread as Is Solution and create another thread for meshing.
You can have a look at following video.
November 15, 2018 at 5:16 pm
VSK1989
SubscriberHi All,
Thank you very much.
Regards ,
V shravan koundinya
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
