Preprocessing
Preprocessing
How to import and edit mesh file?
    • thomasd1
      I have a .msh file I want to edit in Ansys Fluent, When I start a fluent system, then right click on mesh and import the .msh file, there's no option to edit it. How do I edit the file in the mesher?
      Thanks
    • Raef.Kobeissi
      you can refine and adapt a .msh file on Fluent (solution) but you can’t edit it per say.
      Regards
    • j.jeffery
      Hi Reaf,
      What file type is needed to be able to import a mesh and be able to edit it?
      Thanks
    • raul.raghav
      Unfortunately, you cannot edit the .msh file in Fluent. As Raef mentioned, you can refine and adapt the .msh file but not edit it. If you want to edit your .msh file, you can import the .msh file in ICEM-CFD and then make changes to it. And, as far as I know, that's the only way to do it.
    • Raef.Kobeissi
      you can save a file from Workbench to edit it later in the meshing tool within Workbench.
      Cheers
    • anirudhkarumuri
       You can export and save the Mesh file in .meshdat format from Workbench Mesher, and then you can edit it later and thereafter save it in whichever available format you want.
Viewing 5 reply threads
