Preprocessing
Preprocessing
How to import CATProduct to ANSYS without merging it in the Design Modeler?
    • Circle
      Hello everyone,ni want to import a CATProduct (>1 Part) in ANSYS. The thing is, importing CATProducts is possible but i have to merge them to one group/part with seperate bodies in the Design Modeler ... everytime. This further step is necessary to create a Mesh with with the same nodes one the contact surfaces...nIs there a Possibility merging the parts to one group/part in CATIA? So i dont have to do the workaround in the Design Modeler.nThanks!Array
    • Ashish Khemka
      Hi,nnI am moving this discussion to the preprocessing.nnRegards,nAshish Khemkan
      You mean create a multibody part? I don't use CATIA but have a look for components or groups in there. Also try using ShareTopology rather than creating a multibody part as that can be used for the same effect in some cases. n
    • Circle
      Hmm... Share Topology? I give it a try.nTanks!n
Viewing 3 reply threads
