February 2, 2023 at 10:38 am
k1525166
SubscriberIn order to import to Turbo workflow fluent, should you save the domain as different mesh files (Separate Rotor Blade and Stator Vanes) and then specify it in the turbo workflow ?
I'm new to turbomachinery application.
February 2, 2023 at 3:12 pm
Ansys EmployeeI suspect it's explained here https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/flu_tg/flu_tg_turbo_workflow.html
February 2, 2023 at 3:18 pm
k1525166
SubscriberHi Rob,
Thank you for the reply, i have completed that tutorial before.
However, is .gtm file the output from turbogrid ?
Would it be possible to arrange a video call with you and screenshare, as I'm not sure and cannot find anywhere online how i can creat Turbo Grid mesh with Tip gap.
I'm using design modeller to prep the axial rotor geometry, should the tip gap be defined in the design modeller or can it be defined in turbogrid ?
Best Regards,
Alin
February 2, 2023 at 4:11 pm
Ansys EmployeeI've been told .def is a better format. Tip gap etc should be covered here https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/tg_tutr/tg_tutr.html and https://www.youtube.com/watch?v=cFxWUdkcsEs&list=PL0lZXwHtV6Onxxu6EuCXWaOhHUu0AyVV_&index=32
5268
3299
2469
