December 8, 2022 at 5:51 am
Sarat Balla
Hi ,
I am facing issues with importing my engineering materials files (.xml) which I have been using for previous versions. Is there a way to import my materials?
December 8, 2022 at 6:08 am
Subashni Ravichandran
Forum ModeratorHello Sarat Balla
Are you facing this issue with Ansys Discovery 2022 R2?
Please note that Discovery reads only .json format for Material library. -
December 8, 2022 at 6:45 am
Sarat Balla
Hi Subhashni,
Thanks for helping out. I converted my .xml file to .json file. I added it to my local library location. Yet, I am not able to find it added to my materials column of my model.
Thanks in advance,
Sarat
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4504
2971
1449
1322
