How to impose a mass flowrate or pressure drop without boundaires
    • AnthonyB08
      Hi all,
      How can I impose a pressure drop or mass flowrate for my following fluid domain? Would I use a profile UDF?
      I am trying to simulate a representative elementary unit of a packing element.
      A gas will flow upward by induced flow rate or pressure drop. The faces on the top, bottom, right, and left are periodic  while the front and back are wall conditions.
      -Thanks
      Forum Moderator
      I don't think you can use periodic as there aren't one pair of "ends" to the section. Similarly periodic & symmetry doesn't look practical. You may need to model a slightly larger section and use symmetry planes to the sides.
      Gas going up, are you planning on liquid going down?
    • AnthonyB08
      Many sources use this method in ansys for REU. No single phase. Is a pressure drop implementation just a source term?
      Forum Moderator
      Pressure drop would be boundary conditions. You can use porous media or source terms on the cell zones, but I don't think that's what you want here.
    • AnthonyB08
      CFD-based study on structured packing geometry - ScienceDirect
      This was done in ANSYS with 4 periodic boundary conditions and a pressure gradient applied in the z -direction.
Viewing 4 reply threads
