February 16, 2021 at 1:52 pm
Aliosha86
SubscriberHi guys,nI am facing another problem with ansys maxwell. nI want that a current flow into a component with a specific current path. I am trying to divide my component into several parts, assigning non conducting properties to the parts I do not want my current flow into. The model run, but in the end I observe the current everywhere. nDoes anyone know how could I solve this problems? I have also tried to use at the boundary between those materials the insulating condition but it end with an error Current leak.nnCheers,nAlession -
February 16, 2021 at 8:05 pm
icellb1
Ansys EmployeeHi,nCould you show what your components look like, which are the parts you want current flow through which are the ones you don't want, where and how you assigned excitation, where and how you assigned insulating boundary, and the full error message? Also, did you check show conduction path before analyzing? To show conduction path, right mouse click>assign excitation>conduction paths>show conduction paths.n
- Maxwell, HFSS or Q3D?
- Error
5340
3345
2471
