Ansys Products
Ansys Products
How to imprint washer contact area on plate midsurface? (SpaceClaim)
    • jeon hyeon min
      Hi, I wanna ask how to imprintnwasher contact area on midsurface of plate.
      The figure below shows that 3 plates are connected by 3 bolts and nuts.
      I want to make Bolt Pretension on each bolt.
      But the problem happens, when I imprint bolt and nut's washer area like figure below.
      Before make midsurfaces of plates, you can see the area of washer imprinted by bolt.
      When I make midsurfaces of plates like figure below, those areas disappear.
      So I cannot make bolt pretension in Workbench Mechanical.
      How can I imprint those washer areas on plates's midsurface?
    • Aniket
      If it is one time operation, you can use project tool to project the solid imprints on the midsurface:
      -Aniket
      • jeon hyeon min
        Thank you Aniket!
        But the problem is, there are so many plates around those bolts. So if I use Projection, Bolt's projected areas are imprinted to plates that I don't want...
        Is there any other way?
