August 14, 2018 at 7:19 pm
mekafime
SubscriberHi everybody,
How I can to improve my model in Ansys, for the report?. Equivalent Von Misses Stress is greater than 250 MPa.
August 14, 2018 at 7:37 pm
Sandeep Medikonda
Ansys EmployeeHi, Please elaborate on why it is a problem? If it is greater than what you input in the yield stress, please see if this discussion helps?
Sandeep
August 14, 2018 at 8:36 pm
mekafime
SubscriberThanks !
August 14, 2018 at 9:05 pm
August 14, 2018 at 9:55 pm
Subscriber@Sandeep, mekafime found that plot in this discussion.
@mekafime, that graphic was not generated by ANSYS. The data in the graphics was. The data can be gathered manually, but meshing, solving, and then writing down the element size and Max Stress in an Excel spreadsheet. Then Save As the model, change the element size, solve and write the next data point into Excel.
Alternatively, you can use a Parameter on the Mesh Sizing control, and use Workbench Parameter Set to type in the series of element sizes you want as an input and mark as an output Parameter the Max Stress, then lest Workbench Solve All Design Points and let the automation of Workbench automatically generate the table that you could do manually with Excel and Mechanical.
2120
1347
1118
461
