How to include the practical response of a diode in HFSS Design
    • Preeti
      I am simulating a planar array including diodes in HFSS 2020 R2. I am using Lumped RLC boundaries for the same.
      Now, I wanted to include the practical response of these diodes in HFSS so that I can observe the actual response of the structure, which will be obtained, when these diodes will be practically soldered.
      Please help.
      Regards
      Preeti
    • Praneeth
      You can use the diode types which are available in the library of circuit inside AEDT.
      All the very best.
    • Preeti
      Dear Sir Thank you so much for your help.
      Regards
      Preeti
    • Preeti
      Dear Sir As per your suggestions, I have found the required diode in Circuit library of AEDT.
      But, how the diodes in the Circuit will be linked/connected to HFSS model.
      Please help.
      Regards
      Preeti
Viewing 3 reply threads
