Preprocessing
Preprocessing
How to indetify baffles in Fluent meshing
    • Mit
      I am getting the following error while meshing (surface mesh step) a geomerty in FLUENT.  Since "external baffles" is not a name selection or a solid in my geometry, how do I identify what zones the software is referring to here? I have looked through the face zones under display option but couldn't find it. Appreciate any thoughts or suggestions on how to figure this out
      Cheers!
    • SRP
      The error may arise:
      1) CAD is not imported properly.
      2) Surface mesh may get overlap
      Try to repair geometry in spaceclaim.
      Thank you
    • Federico Alzamora Previtali
      Hi, I suggest you bring inspect your geometry in SpaceClaim. In the structure tree, right click on your model and select Check Geometry. SpaceClaim will hightlight any potential faults in your geometry.
      I hope this helps!
      Federico
