3D Design
3D Design
How to input equation in workbench
    • Jimmyhan
      I can use DM draw my model, and define the dimension what I want. Besides giving a value I can set the dimension to the parameter and give a name to this parameter. After this step, I can change its value in the workbench.   My question is how to use an equation in the workbench for change the parameters? For example, I want to make the ratio between total value and wet area equal to a constant. when I change height all dimensions will change and the result can be calculated by workbench itself and use in DM.
Viewing 0 reply threads
