How to input Turbulent Intensity as expression
    • Shivesh Sharma
      I am using ANSYS 2023 R1 and running a simulation based on an experiment. The input for velocity and turbulence intensity is based on a power law profile. I can enter the velocity as an expression, but when I try to do the same for turbulent intensity, I get an error that says ‘expression is not single-valued.’ I have also tried to input this expression as a new parameter, but it still gives the same error. Can anyone help me solve this problem?
    • Essence
      Try using abs(y) instead of only y in the expression.
      • Shivesh Sharma
        Hi, Thank you for your response,
        I have tried using abs(y), but it is giving the same error. I have attached a screenshot for your reference.
    • Essence
      You are getting this error because the present expression needs to evaluate to a single valued constant. If it is not a constant you will get the error you are seeing.
    • Shivesh Sharma
      I'm inputting the turbulent intensity as an expression because it varies with height. If I were to use a single valued constant, the turbulent intensity would not change with height, which means I wouldn't need to use an expression.
    • Essence
      I hope this Forum discussion will help you. Please refer the Forum thread:
      https://forum.ansys.com/forums/topic/turbulence-intensity-expression-inlet-outlet/
    • Shivesh Sharma
      Thank you
Viewing 5 reply threads
