How to iterate export moments at range of points in yz plane
    • ahmedshafie
      I want to find moments at range of points ,so i think i ve to do iteration with udf but i dont know how
    • Keyur Kanade
      Can you please explain in detail with some images?
      Regards Keyur
    • ahmedshafie
      thanks for your reply , well i dont have images , actually i want to generate image or data , i want to calculate moment at around x axis at each point in a plane , so i can have a contour or i can export them in excel file ( each point with moment value at it ) , fluent let me only measure moment when i input x,y,z coordinates , but i want to iterate so i can find range of points .
    • Keyur Kanade
      I am not sure if I understand your question correctly. Sorry about that.
      You can check monitors. You can see following in help manual.
      Regards Keyur
    • DrAmine
      No this is not possible to show moments or force as contour plots. You need that for each face and store that in variables.
Viewing 4 reply threads
