October 22, 2018 at 3:09 pm
vkumarsingh388
SubscriberHello,
i have two geometry from that i have to make an assembly, it is easier to do in solidworks by defining mate, but i want to know how to use something like that in design modeller.
October 22, 2018 at 3:16 pm
Keyur Kanade
Ansys EmployeeThere is no direct command like mate in DM.
You can use Create --> Body operations and move your body at particular location.
You can find more details of these commands in help manual. You can also see following video.
Keyur
October 23, 2018 at 4:08 am
Keyur Kanade
Ansys EmployeeHi,
Did it help you? Are you able to assembly your geometry?
Also, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
Keyur
October 23, 2018 at 5:13 am
vkumarsingh388
SubscriberHello,
it means i have to import all geomtries into DM and then i have to place them correctly and have to define contacts in ANSYS Mechanical, is it?
October 23, 2018 at 6:50 am
Keyur Kanade
Ansys EmployeeYes, its correct.
Keyur
October 23, 2018 at 6:51 am
Keyur Kanade
Ansys EmployeeAlso, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
Keyur
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2616
2098
1323
1108
461
