November 7, 2018 at 3:18 pm
jackhero
SubscriberI ran a simulation for studying the contact behavior between a rod and a block, having bonded connection. I used e-kill and e-alive commands to get the element birth and death, for contact and the target, in Ansys workbench. The purpose is to simulate the debonding using kill command.
I would like to ask when I use element birth and death (ekill) how can I get the number of interface elements or cells killed? I intend to get the number of elements before and after kill to get the total percentage of the killed cells or elements during debonding.
esel,s,type,,mycont
esel,a,type,,mytarg
ekill,all
allsel
esel,s,type,,mycont
esel,a,type,,mytarg
ealive,all
allsel
Thank you -
November 7, 2018 at 11:49 pm
Sandeep Medikonda
Ansys EmployeeJack,
I don't think there is a way to do this in the GUI. when we select the element to kill using ESEL or other commands, it is recorded in the solver out file. Or you can write it to a text file using commands.
Sandeep -
November 8, 2018 at 5:26 am
jackhero
SubscriberThank you for your reply.
Can you please guide me on how to get the number of elements using commands? I searched for writing into text file, and the vwrite command is suggested. But which command or set of commands I shall use in Ansys Mechanical to get the number of elements so that the vwrite command could be used to write the result in text file?
November 8, 2018 at 10:18 am
Rohith Patchigolla
Ansys EmployeeHi Jack,
Please try the below script.
!Beginning of script
ESEL,s,live !live elements
ESEL,inve !killed elements
*get,ecount,elem,,count
*dim,killed_elems,,ecount
*vget,killed_elems(1),elem,,elist
*CFOPEN,killed_elem_list,txt,
*VWRITE,killed_elems(1)
(F8.0,TL1,' ')
*CFCLOSE
!End of script
Best regards,
Rohith
November 9, 2018 at 1:41 am
Sandeep Medikonda
Ansys EmployeeJack, it looks like Rohith has answered your question.
As an experienced member of this forum who asks good questions. I request you please close discussions whenever your original question has been answered.
This will not only help new users but will also help us in providing better support on this forum. Please take a moment to look at the Guidelines on the Student Community.
Sandeep -
November 9, 2018 at 8:34 am
jackhero
Subscriber@Sandeep, @Rohith
Thank you for your reply and guidance.
July 21, 2020 at 2:39 pm
Shekhar
SubscriberHi Rohith,
If you can please tell me what is (F8.0,TL1,' ') used in your above code between commands *VWRITE and *CFCLOSE?
2066
1279
1096
459
