December 23, 2022 at 2:44 am
limch4
SubscriberHello, everyone I'm a graduate student to study Electromagentic in Korea.
I want to link static structral and mawell using workbench.
I made it to link from Maxwell to static structral. But the oppsite way link isn`t succes ( from static to Mawell).
I can`t find why appear this situation. So, I need to help from Ansys Fourm user to get solution.
Thanks you to read my post. I hope to Every one will be happy :)
December 28, 2022 at 4:11 pm
GLUO
Ansys EmployeeHello,
Are you trying to do a 2-way coupling, or just one way from structural to maxwell?
GLUO
December 29, 2022 at 1:16 am
limch4
SubscriberHello, GLUO
Simply, I want to simulate electric field when plate is bending.
So I try to link from static structral to Maxwell but it is not doing well.
And I I do not really know the difference between "2-way coupling" and "One way coupling".
Can I ask for an additional explantion about 2-way and one way couping??
Thank you, GLUO!
January 4, 2023 at 7:38 pm
GLUO
Ansys EmployeeHi,
One-way coupling: B is taking data from A.
Two-way Coupling: For each iteration, B taking data from A, and feed data back to A after calculation.
GLUO
January 5, 2023 at 1:38 am
limch4
SubscriberHello, Gluo
Tnanks to your explantion!
I think I need to use 2-way Coupling.
Can you explain about 2-way Coupling to Maxwell taking date from Static Structural?
Thank you.
January 9, 2023 at 6:00 pm
- Maxwell, HFSS or Q3D?
- Error
2706
2146
1357
1144
462
