October 3, 2018 at 8:23 am
October 3, 2018 at 12:31 pm
Sandeep Medikonda
Ansys EmployeeHi Adisa,
Please see if this discussion helps? See if Reset Layout helps as suggested in that post. It does usually in most cases but if it doesn't you might want to delete or rename the corresponding version folder in your appdata:
%appdata%ansys
Sandeep
Best Practices to post on the Student Community -
October 3, 2018 at 12:48 pm
Adisa
SubscriberThank you, I solved the problem.
2088
1319
1108
459
