how to loop over wall boundary
    • Achini
      Hello!nnI want my udf to loop over the wall boundary and calculate particle ( particles will be introduced via dpm injections) to wall distance at each iteration.nHow can I do that?begin_f_loop(f, tf)n{tf = Lookup_Thread(d, zone_id); /*create a thread pointing to the wall*/nif Thread_ID(t)=3;n/*rest of the commands*/nnWill I be able to use the above code with an if condition to identify select the wall boundary via boundary zone ID.nPlease help!nThank you!nn
      You can loop over the wall, but what use is it if the wall knows how close a particle is? n
    • DrAmine
      Purpose? What do you want to do?n
