June 13, 2023 at 12:22 pm
Domiziano Dario Tosi
SubscriberI tried to make an elipsoid with L 20um, W 15um and H 7um but i could not find a tool for it. So I divided the shape in 1/4 and then applied the mirror tool but when I do 1/4th of the shape the curve is deformed like shown in the picture, there is a way on making it without any distortions? thank you
June 14, 2023 at 10:56 am
Aniket
Ansys EmployeeYou can use Equations to create an ellipsoid in SCDM.
You can use equations of the ellipsoid as follows:
This can be used by choosing curve type as custom and entering the above values there, more info at Geometry from Equations (ansys.com)
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7592
4440
2953
1427
1322
