May 26, 2021 at 4:20 pm
Davide_P
SubscriberHi everybody!
I'm trying of performing an FRA with external results imposed as a set of displacements bouday conditions.
In the picture below, we have a set of frequency dependent displacements (colums) per each degrees of freedom (raws). These results come from an external MatLab analysis (but this is not relevant).
So, I ask you how can impose these frequency-dependent displacements, into the APDL framework, in order to execute the FRA. My aim is to calculate the frequency dependent stresses observing the coloured map.
Thanks!
Davide
May 28, 2021 at 7:31 am1shan
Ansys EmployeeYou might want to have a look at this code - https://forum.ansys.com/discussion/1157/apdl-transient-analysis-only-registering-1st-acceleration-step, its something similar.
Regards Ishan.
May 28, 2021 at 9:34 amDavide_P
many thanks for your suggestion! It seems to be in line with my needs or strongly related!
Regards :)
Davide
2524
2066
1285
1096
459
