How to make a high frequency inverter ?
    • rminhazu
      I am working on WPT using co-simulation using Maxwell and Simplorer. But, I am facing problem regarding inverter and rectifier and not found any tutorial. I need help about analysis setup and controller circuit. Please, Help me. Thank you
    • Navya C
      Hi @rminhazu If you are on 2021R1 and above you can look at the example under Maxwell. This may help you
      Open example>Maxwell>Wirelss Charging
      Regards Navya
    • rminhazu
      thank you I am using 2020r1. how can add it ?
    • Navya C
      Hi @rminhazu One thing that is missing in your circuit is ground. You should have ground on both sides.
      If this did not solve the issue To look at the example suggested you must have 2021R1 or higher installed.
      If not you can look at some existing twin builder examples to get some ideas on inverter and rectifier.
      Regards Navya
Viewing 3 reply threads
