November 21, 2017 at 7:28 pm
sy2516
SubscriberHello,
I am running Fluent in a supercomputer. From the User manual, I only found how to use wd cyclone1000.dat to export data file. But I would like to export particle history data. How can I export particle history data in batch running fluent? Thank you.
December 7, 2017 at 2:05 pm
jwLeeds
SubscriberYou can do this quite easily without the need for configuring a batch file. In the FLUENT setup GUI, go to File -> Export -> During Calculation and select Particle History data (or indeed Solution Data, depending on your requirements). Follow the setup from there. On execution of the job, FLUENT should output the data files into the usual location in the working directory.
2656
2120
1345
1118
461
