April 19, 2022 at 2:05 am
kevin.anny
SubscriberI'm trying to solve the current of a moving solid in magnetic field, I tried frame motion and mesh motion, but the current remains zero. While I change the solid to a very viscous fluid, MHD worked. It seems Fluent don't solve the solid motion in magnetic field. How could i make it works?
Any help will be highly appreciated. Thank you!
May 6, 2022 at 12:55 pmKR
AdministratorHello Which version of Fluent are you using?
Also, how are you setting up the motion in the solid? Can you share some screenshots?
Karthik
May 6, 2022 at 1:20 pmMay 6, 2022 at 4:00 pmKonstantin
Ansys EmployeeHello This is a limitation that MHD will not generate the Lorentz force inside the solid (no source terms in solid zones defined to accommodate this). The best solution is to do exactly what you are trying: use fluid with properties of solid. You can fix the velocities inside the zone or use high viscosity.
May 6, 2022 at 4:03 pmkevin.anny
SubscriberThank you for the answer.
Viewing 4 reply threads- The topic ‘How to make MHD model works in a moving solid’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
