February 11, 2022 at 5:14 am
Amruthapreethi
SubscriberI am simulating 2D RDE combustor using species transport. The fuel-air mixture is present everywhere in the domain. I have tried patching to put products in the domain. But it works initially at the start of solution only. So, I have tried partitioning into zones. but I am unable to place different mixtures in two different zones. How to divide into zones as shown in the figure below:
February 11, 2022 at 11:01 amRob
Ansys EmployeeHow are you adding fuel & oxidiser into the domain? Staff are not permitted to open attachments so please post the image so we can see it.
February 11, 2022 at 11:14 amAmruthapreethi
SubscriberFebruary 11, 2022 at 11:28 amRob
Ansys EmployeeOK. Check the cell zones and make sure you have the mixture on both. Fluent doesn't do this automatically and it can catch people out. That may solve the rest of the problems. How are you stabilising the flame?
As an aside, when plotting 2d contours do not select any surfaces. Fluent will (probably) auto select something, but leave it to decide. I think you're plotting on the interior which gives you a load of lines rather than a smooth surface plot.
February 22, 2022 at 11:13 amAmruthapreethi
SubscriberFebruary 22, 2022 at 2:42 pmRob
Ansys EmployeeBoth cells zones should be the mixture, the fuel & oxidant volume fractions are set on the boundaries.
Viewing 5 reply threads- You must be logged in to reply to this topic.
3756
2573
1823
1242
598
