October 17, 2018 at 2:10 pm
Najib.Sarbini
SubscriberIm really new to ansys fluent and i need to figure how to make pulsating flow on fluet,
my case study is a 2d rectangular tank with one crossflow and one pulsating jet at the bottom of the tank.
October 17, 2018 at 2:36 pm
Keyur Kanade
Ansys EmployeeDo you want to do it in AIM or in Fluent?
Keyur
October 17, 2018 at 2:44 pm
Najib.Sarbini
SubscriberFluent
October 17, 2018 at 2:48 pm
Keyur Kanade
Ansys EmployeeMoving to Fluid Dynamics category.
Keyur
Najib.Sarbini
SubscriberAlright thank you
October 17, 2018 at 3:14 pm
Ansys EmployeeAt present you'll need a User Defined Function or transient profile to do the pulsed flow. The former is covered in the Customisation Manual, the latter in the User Guide.
October 17, 2018 at 3:31 pm
DrAmine
Ansys EmployeeI want to add to what rwoolhou already wrote: Is the pulsation for an inflow boundary?
October 17, 2018 at 3:43 pm
October 18, 2018 at 3:55 am
Karthik R
AdministratorHello
Rwoolhou and abenhadj are suggesting that you use ‘User Defined Functions (UDFs)’ or ‘Profiles’ in Fluent to create a pulsating jet. UDFs are codes based on some Fluent macros where you can write an analytical expression for your velocity as a function of time. This UDFs will be compiled, loaded, and hooked to your Fluent case as a boundary condition. You can find more information about this UDF in the Fluent customization manual.
About ‘profiles’ - profiles are external files which contain information about the velocity of your pulsating jet as a function of time. These files can directly be read into Fluent. You will need to create these files in a specific format, which can be found in the Fluent Users Guide.
I hope this clarifies both their answers.
Best Karthik -
October 18, 2018 at 5:00 am
DrAmine
Ansys EmployeeTo clarify my question: Is the velocity you provide at your inlet constant or does undergo a pulsating profile.
If the velocity at the inlet is not really pulsating (say behaving as sin profile) which I think actually, then the jet pulsation itself in the core will be due to external destabilizing forces and other stabilizing forces (surface tension forces if you are injecting liquid into a gas and viscous forces)
2564
2078
1293
1106
459
