August 16, 2018 at 3:26 pm
abinash
SubscriberI am designing a Half Bridge Model (a phase leg) in Q3D Extractor.
Q3D Extractor apart from its main role (parasitic extraction), also allows to view current density plot of the model.
I am able to manipulate (change) the frequency before simulating but there is no such thing for current in Q3D.
How does the current density plot in Q3D work then?? Where does the current density plot get its input data from??
August 17, 2018 at 2:45 pm
kgavini
Ansys EmployeeYou can change using field Overlays > Edit Sources or Q3d Extractor > Fields edit sources
August 17, 2018 at 8:23 pm
abinash
SubscriberIt works. Thank you so much @kgavini
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1345
1118
461
