February 28, 2022 at 7:13 am
Susan
SubscriberDear all,
For the parametric study in workbench, I want to define another output parameters in fensap-ice module besides the default ones, such as Total Beta in A5 Solution Droplets.
Is that possible?
Thank you so much.
Best regards,
Susan
March 10, 2022 at 10:02 amShoaib Shah
Ansys EmployeeHello Susan
For parametric studies only the ones you can see in the properties panel on the right hand side can be parametrized. By clicking on each setup (flow, droplets,ice) cell, the properties panel will show parameters you can do what if studies for. This will be a box you can check.
Thank you
March 23, 2022 at 5:06 amSusan
SubscriberDear sshah Thank you for your attention and reply. Yeah, I see that but the problem is the parameters can be picked as variables are not which I want, and I want to define the input and output parameters by myself.
Anyway, many thanks.
Regards Susan
2524
2066
1279
1096
457
