March 17, 2022 at 1:52 pm
MelihNabi
SubscriberHello I am pretty new to community so I give my regards to all of u who helped eachother and developers. I am trying to map a blast to 3d solid S-ale fluid. It doesn't seem like *ALE_MAPPING working properly. I have used INITIAL_ALE_MAPPING and BOUNDARY_ALE_MAPPING with success before. I tried full deck restart to archive the same result but as @jday said in 2021 Its not working properly. I want to map a blast after initialisation and after some time. How can I use the *ALE_MAPPING with success?
March 18, 2022 at 9:45 amDrAmine
Ansys EmployeeWhich Software are you using?
March 18, 2022 at 10:14 amMelihNabi
SubscriberI am using LS-DYNA, Looking for a guide for using *Ale_mapping card.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2726
2148
1357
1150
462
