How to match time step settings for a coupled simulation
    • Rashi
      I'm conducting an FSI simulation with Fluent and Transient structural coupling.
      Influent I have set 0.01 (s) step size with 10 number of time steps.
      I have finished the simulation in fluent and imported the temperature data to structural.
      But I cannot get the time step values correct whatever value I put I get a question mark in the "analysis settings".
    • Rashi
      Got it solved!n
    • Karthik R
      Administrator
      Awesome! Thank you for this update. Good to know that you are able to move forward with your work.nGood luck!nKarthikn
    • Rashi
      Thank you, Karthik!nnQuick question does ansys have the capability of simulating the effect of time-temperature variation of materials? for example as for simulating stress-relieving occurred due to heat treatment?.n
    • Karthik R
      Administrator
      Yes, you should be able to. For this, you will need to specify the variation of the material property with temperature as a table under Engineering Materials.nKarthikn
    • Rashi
      Hi Karthik,nBut Ansys does not have time dependency when it comes to material properties right? Where the rate of heat treatment can effect the mechanical properties?n
Viewing 5 reply threads
