How to measure average/max pressure between inlet and outlet
    • mossaied2
      Hi
      I wanna measure pressure drop between fluid inlet and outlet, both max and average. My way now is through Reports -> Surface integrals -> Facet maximum and I choose Total Pressure. So is that the right ways?
      Thanks
    • DrAmine
      Make area weighted average of total pressure at inlet and outlet in separate report definitions. Then create a new report definition of type expression where you make the difference between both report definitions.
    • mossaied2
      Thanks Mr Amine, but how about the max pressure?
      Also if I have a surface and I wanna report the temperature at some points (say 10 points that I know their z,y,x coordinates) on that surface, how to do that?
      Thanks
    • DrAmine
      Same but with facet maximum at the boundary.
      For points you create them based on theier coordinates and evaluate them via vertex average.
Viewing 3 reply threads
