June 28, 2019 at 8:15 am
nadeemrather
SubscriberIf I use a probe to detect the etic field from a coil antenna then how can do the same in HFSS given the fact that the coil antenna tested has a matching circuit and in simulations, don't have any, Rather I have matched the port impedance to the antenna. which is a complex impedance of antenna resistance plus inductive reactance of the coil... I am not able to get the results on my simulation when trying to match it with measured. I used a vacuum cylinder of the area as the probe flux area.
p.s I just want to check the magnetic field received by a specific flux area near the antenna, which should be same as measured
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1809
1236
594
