Preprocessing
Preprocessing
How to measure the heigth of adjacent cell to wall in a created Mesh?
    • José Mantovani
      Hello everyone!
      So, I need to know the heigth of wall adjacent cell in a created Mesh. The mesh generated is a 2D structured mesh, below have a image of my mesh with zoom near wall around step. As I said in title, I want measure the heigth of first cell from the wall on a created mesh using Ansys Meshing.
      Thanks for the opportunity!
      Mantovani.
    • raul.raghav
      Mantovani, see if the following screenshot helps you understand the process.
      1. Activate the information tab inside the meshing; 2. Select the mesh node selection tab; 3. Select the mesh nodes; 4. Look for the dimensional information from the table. There is probably an easier way to do it, but this definitely works.
    • José Mantovani
      Thanks very very very very much Rahul!!!!!!
    • Vishal Ganore
      Also, after selecting node, you could also see the x,y&z co-ordinates in a status bar.
    • José Mantovani
      Thanks Vishal!
Viewing 4 reply threads
