October 12, 2018 at 7:14 pm
October 12, 2018 at 8:02 pm
Sandeep Medikonda
Ansys EmployeeSam,
Is this for SpaceClaim or Design Modeller?
In SpaceClaim, see if the Combine or Fit Curves tools help?
Sandeep
October 12, 2018 at 8:13 pm
sameerfares
SubscriberSandeep,
It's for SpaceClaim.Combine or fit curves dont help unless i am doing something wrong.
Thanks,
Sam
October 12, 2018 at 8:45 pm
Sandeep Medikonda
Ansys EmployeeSam,
So, Fit curves should work. Below, I have 3 lines.
I then selected the Fit Curves option to join
Alternatively, you can also use the Fill tool as shown here:
Hope that helps.
Sandeep
Best Practices to post on the Student Community -
October 12, 2018 at 8:54 pm
sameerfares
SubscriberSandeep,
yes it worked. i forgot to check the check mark.
Sam
December 2, 2019 at 10:24 am
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2600
2086
1317
1108
459
