December 3, 2019 at 6:10 am
December 3, 2019 at 12:16 pm
SubscriberWhy do you want to merge the lines?
If you do something like pick both lines and Pull a surface from them, you will get a single surface body with two faces and the lines will disappear.
If you want two beams to be connected, first you convert the lines into beams on the Prepare tab and then use the Share button on the Workbench tab to weld them together at a common node.
December 3, 2019 at 12:32 pm
FrankD
Ansys EmployeeFurther, Fit Curve makes a spline (which by definition cannot have a sharp internal discontinuity)
If you need a surface with no visible tangency, upon extrusion, then you have to make sure to sketch a tangent arc (or spline) between the straight lines, first.
F
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5242
3299
2469
