March 14, 2021 at 3:17 pm
sophiemcg
SubscriberI am trying to model the cylindrical scaffold as shown in black and white according to the one shown in blue in Ansys Workbench. The one shown in blue was created in Abaqus and used mesh CD310, 10 node quadratic tetrahedral elements.
I have tried to insert edge sizing along the edges and circle faces. I have also added method>tetrahedrons>quadratic and it is still not looking anything like the one generated in abaqus.
Thank you.
March 14, 2021 at 3:41 pmpeteroznewman
SubscriberMarch 14, 2021 at 8:18 pmsophiemcg
SubscriberHi, nThanks so much that has helped a lot! nI now have the mesh shown. nI still cannot get the elements on the face of the circles to appear as they do in the above model (also some vary from each other). nI also need the top face to be split in 2 as shown in the image above. I have tried edge sizing along both the long and short edge and neither worked.nAdditionally, the circles located on the top layer did not change from the original mesh I had - they always seem to appear originating at the centre and pointing outwards. nDo you have any suggestions for the above issues. Thanks in advance. nn
March 14, 2021 at 9:00 pmpeteroznewman
SubscribernWhy do you need the same mesh on the circular face as the Abaqus mesh?nCan you get the Abaqus mesh file so that you get the exact same nodes and elements?nI don't see the split line you are talking about.nMarch 14, 2021 at 9:41 pmsophiemcg
SubscriberI am trying to validate my model (b+w) by comparing my results to the ones seen in the paper (blue) to ensure that my FEA representation is accurate. I will then be changing material properties etc. to investigate their effects. I am very close to getting identical results as the paper, however, I would like to get my mesh as close to theirs as I can to get my results the same.nThe number of elements in the Abaqus mesh was 1,894,283. My model currently has 2,700,500. nI have attached a photo of what I mean by the split line nn
March 14, 2021 at 10:22 pmpeteroznewman
SubscribernIn SpaceClaim, or any other CAD editor, split that face. I would create a plane and use the Split button.nResults should be mesh independent. You can use a larger element size to get closer to the Abaqus node count.nMarch 15, 2021 at 10:00 pmsophiemcg
SubscribernHi, nI cannot seem to split the face using SolidWorks but I may just leave it as it. nRegarding the circular faces - do you have any suggestions for making them look more like the abaqus model - the elements are a lot more evenly spaced out in that model compared to mine. I have tried face sizing and edge sizing along the circles.nApologies for all the questions - Thanks so much nMarch 15, 2021 at 10:25 pmpeteroznewman
SubscribernANSYS meshing software creates valid elements for its solver. ABAQUS meshing does the same. The elements are valid in both cases. There is no reason to force the ANSYS mesh to look exactly like the ABAQUS mesh. They are just different.nViewing 7 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2564
2068
1289
1106
459
