How to model 2way FSI in a rotating tank?
    • masoudmtl
      Hello everybody,
      I have been busy with this problem for over a month and I would
      really appreciate it if someone could give me a kind help or introduce me to a
      helpful reference. Here is the problem:
      There is a tank that is half full with water and half with air.
      There are a number of springs inside the tank which would vibrate with the
      rotation of the tank and interact with the water and create some moments on the
      structure of the cylinder. In detail:
      1.      Consider a circular tank
      with a diameter of 20cm and a height of 20 cm. The wall of the tank is 5mm
      thick.0
      2.       There exist 4
      springs attached to the floor of the tank in a circular pattern. Each spring is
      attached like a cantilever beam. That is one end attached to the floor of the
      tank and the other end is free.
      3.      Also consider that the
      axis of the springs is parallel to the axis of the cylinder but 5cm apart
      radially. Each spring has a wire thickness of 0.2mm and is 20 cm tall with 50
      turns.
      4.      The water height is 10cm
      inside the tank and the rest is air. Also, gravity acts downward in the
      direction of the axis of the cylinder.
      5.      Imagine the tank is
      rotated with a varying rotational velocity of 100*sin(2*3.14*t) around its
      axis.
      It is desired to measure the torque on the tank with time. We are
      going to drive the system with a motor and we are interested to have an
      estimate of the behavior of the system. Clearly, the problem is a 2way FSI
      (Fluid-Structure interaction). My problem in the first place is in coupling the
      Ansys transient structural with Ansys Fluent. In detail, I want the Ansys
      Fluent module to recognize the rotation from the structural module and apply it
      to the fluid. Then, I am interested to see the interaction between vibrating
      springs and the water inside the tank.
      I am enthusiastically waiting for your responses my friends.
      Thanks,
      Masoud
    • 1shan
