Preprocessing
Preprocessing
How to model beam and shell together?
    • Balli
      Hello everyone,
      I have 8 platforms to calculate weight capacity. (Figure Model,model2 and model3) And my computer is not able to perform the analysis for shell models. Because of some platform models too big even I use symmetry. That's why I don't want to use shell models. I thought I can model beam and shell together. The general model will be beam and critical regions will be shell. I will use a rigid connection between them. But the problem is the center of gravity. When I transform the 3D to 1D lines are going different height because of the cross-sections. I'm moving them to the same level but at this time the model is changing. I mean the center of the solid model and the line are not going on the same height. If I move the solid to down, the geometry will change. Should I neglect that situation? It's really hard to explain what I'm trying to explain, but if you check the figure you'll see the red boxes that I want to highlight the regions. If I move the solid to down the connection will be changed. Is it acceptable? (Figure 1,2 and 3)
      Or the second option is to use the original center of gravity for all of them. But how can I connect these beams that are located at different levels? (figure problem2.1, problem2.2)
    • Aniket
      Ansys staff can not download images on the student portal, so if you want to reach a larger audience to get answers from, please insert the images inline.
      -Aniket
    • Balli
      Thanks for your reply.
      I didn't know that. So you may see the images below.
    • Aniket
      you can use contacts right? or do you want to share nodes? You will have to turn shell thickness effect on and use larger pinball radius.
    • Balli
      Actually, that's not the problem.
      I want to use beam and shell elements together. I will connect them rigidly with fix joint. So there will not be a stress concentration at the connection point. But the problem is a centerline roblem between the center of the beam element and the center of the shell element. They are not in the same line as you may see the first and seventh picture above.
      How should I deal with this? Should I move the shells in order to set the centers on the same line? Is this an acceptable approach?
    • peteroznewman
      The fixed joint can connect the end of the beam with the offset edge of the shell elements and transfer the load. Don't move any beams or shells, that would be changing the geometry you are trying to simulate.
    • Balli
      Great peter!
      Thanks for your reply. I was so confused about whether changing the geometry or not. I am going to try this way.
Viewing 6 reply threads
