Ansys Products
Ansys Products
how to model electric circuit in ansys ?
    • narsingchappe
      i am working on piezo damping of the cantilever beam using shunt damping, but i have problem for making electric circuit to the beam.so how to solve this issue.?n
      Do you need to model the circuit or the result of whatever the circuit does to the beam? Ie do you need to know where the electrons/electric are going, or their resulting force? If it's the latter you probably just need a boundary condition in Mechanical. n
    • narsingchappe
      I need to make the model the circuit to the beam so that i can find the results i.e the damping of the vibrations. i find the natural frequency without circuit i.e without damping ,now i want to find the frequency after damping . i am applying unit load to beam ,due to piezo patch electric voltage generated and by external resistance and inductance the resonance can be happen to find frequency. n
