How to model fully submerged structure in AQWA
    • nasmuhd
      Hi, i am a student doing my master research using ansys aqwa for offshore marine lifting operation. I need to model my structure to be fully submerged (no waterplane surface) however i get error saying that structure 1 is found to be fully submerged, but it diffracting surface does not form enclosed body but my model is just a box cube which is fully enclosed. Can someone clarified this problem for me. Thanks n
    • KR
      Administrator
      Hello,nI've moved your question to the Structures category as it more closely aligned with our product line. We will be responding to this question shortly.nThank you.nKarthikn
    • KR
      Administrator
      nThe warning message you are seeing is currently being reworked in our next release 2021 R1. In the meantime, the warning can be safely ignored, and you should be able to proceed with your simulations as normal.nThank you.nKarthikn
    • nasmuhd
      Hi Kremella, there's several inquiry that i had regarding AQWA.nRefer to this link
      for splashzone analysis study, you can see that the model include a heave compensation, HC (spring element) in their analsysis. My question is how do u model such element for Heave Compensator? what option should I use? nAppreciate your reply or any rep from ANSYS. Thank youn
Viewing 3 reply threads
