How to model parallel-nonlinear spring dashpot model in ansys mechanical with COMBIN elements
    • alibakhtiari
      I wonder to know how it is possible in ansys mechanical to model parallel spring-dashpot model with considering nonlinear behavior of the spring.
      I know that COMBIN 14 element can model a parallel spring-dashpot model, but it only considers linear behavior of the spring. However, COMBIN 39 element which is used to model a nonlinear spring, does not provide the damper.
      Which COMBIN element or technique you know which I can use to model a nonlinear spring-dashpot in parallel?
      Thanks.
    • peteroznewman
      You can connect both a COMBIN14 and a COMBIN39 element to the same two nodes and get both a dashpot and a nonlinear spring.
