November 28, 2022 at 3:14 am
Chee Min Leong
SubscriberHi,
I would like to know how I can replicate the relationship between the two solids (image A) as if they were pipe walls (image B - highlighted sections) as shown in the images below.
Image A
Image B - Highlighted Wall Section
The reason for being one cell thick was so that I could later incorporate fluid between the two solids and perform FSI for a pipe conveying fluid in 2.5D since FSI is not possible in 2D (or so I read).
I am also working on a 3D FSI model for it but the simulation takes a long time even after symmetry. I am just wondering if there is an alternative.
November 28, 2022 at 7:44 am
Erik Kostson
Ansys EmployeeHi
Use perhaps 1/4 symmetry – so model only one quarter perhaps.
(Cyclic regions can not be used so hence 1/4 is the way to reduce the model size)
All the best
Erik
November 28, 2022 at 10:46 pm
Chee Min Leong
SubscriberHi Erik,
Thanks for the suggestion. I don't think I could use 1/4 symmetry in my case because the pipe will swing side to side (along the x-axis), but do correct me if I am wrong. Here is a video of the phenomenon I am trying to replicate,
Cheers,
CM
Hi
This is like nonlinear flutter/instab. – perhaps not then since is chaotic motion.
All the best
Erik
Yes. It is a nonlinear flutter for the first mode shape which is what I am trying to model. As shown in the video between 0:05 to 0:20, the motion of the pipe is generally on a single plane.
Hence, it is possible to use symmetry which is what I am currently working on as well but was wondering if it could also be done in 2.5D to reduce computation time.
Hi
If it is in one plane perhaps one can use 1/2 symmetry (2.5 D there is nothing called like that in Ansys – cyclic symmetry/region can not be used here which is kind of 2.5 D perhaps).
So just use full model, or if it moves in a single plane perhaps 1/2 symmetry. All the best
2138
1349
1136
462
